Hi,
I noticed a bug in the "effects of adding" section on the pool math app.
Here in the UK, thin bleach below 5% is readily available in supermarkets. However, when entering the % below 6%, the app doesnt scale below 6%.
For example, if x amount of 6% bleach would up FC by 5ppm, if you lower the percentage to 1% bleach, it still says that that same x amount ill raise FC by 5ppm.
Instead, in the main app, if I alter my current and target FC levels, the app does correctly give the correct amounts of bleach required, even for 1.05% bleach.
Hope I have explained that well.
Regards.
Regards.
