My question is, can I increase flow back to a pool water feature by increasing pipe size from 1.5 to 2" on the pool pad outlet side only and not changing anything else?
Our pool was originally plumbed all 1.5" with a 18" Sheer Descent, stair jets, return jets and with a Pentair Superflo VST it all runs fine, if we want a little more output for the sheer descent towards the end of the season, we can crank the RPM and just close back the pool return jets a little to force more flow through the water feature return pipe. The run is about 60+ feet filter pad to water feature and 1.5' above water level, with very minor slope up to pool (no check valve was required). I physically measured the flow (bucket and watch method) from the 18" Sheer Descent at full RPM (3450) and only waterfall valves open. It was about 33 gals per minute, but it's also the end of the season and the DE filter is starting to restrict the flow by at least 20%.
We have no reliable pool company that I can get a straight answer from at the moment.
We are replacing the patio and coping above the sheer descent and were hoping to install a 3 or 4' sheer descent in place of the 18" one and continue to use the main filter pad pump. So I thought about upgrading the output side of the pool plumbing to a 2" pipe run. Before I commit to an installer, I am trying to determine if this alone would this help increase the flow in the pipe to more adequately supply a 3-4' Sheer Descent with a small projection?
My read on the Sheer Descent specs seem to indicate it would work up to about a 3' sheer descent, but I'd like to install a 4' one and be sure it would work, but don't want to commit only to learn later it isn't enough flow.
Moving to a 3hp Intelliflow is a possible future option, but the Superflo VST still has some good life in it.
The cost to install a separate run, cut new dual inlets and separate pump goes above our available budget.
