I have an in ground white fiberglass pool 23,000 gallon 16'X36' depth 3'-8' since 97 when we bought house. Pool was put in 80-81 believe it was called an Ester Williams. Had it re-gel coat 2015, lasted till 2022. Last year had Ecofinish put on looked great, had some areas that company will take care of (off season). This year noticed dark brown blotches mainly on vertical part of stairs but small ones else wheres. Checked it out and used vitamin C did the trick. Got some ascorbic acid at pool store. Added it to pool as instructed used Mikes Magic blue after acid, and pool fluff filter. After a day or two running pump, back washed pool looked great spots gone. After 4-5 days noticed a brownish ring around pool. Checked an area with ascorbic acid and presto ring disappears. I am on well water so not a great mystery where coming from but never had this bad an issue. How do you keep all metal out of pool once stains removed?
Thanks for any thoughts on the matter.
