Hi,
I am having a bit of a problem or I might think there is one.
I installed an easytouch system with an intelliflo pump and intellichlor and a jandy jxi heater.
Everything is working correctly however the heater button doesn't work when I push it, for some reason. I put it in service mode and the button works just not in auto.
I can have the heater set in the settings with a max temp and everything works fine, but I don't want to heat the pool all the time.
I want to be able to turn the heater on manually with the heater button let it heat than when I am done shut it off manually.
The option to turn it on and off with screenlogic2 works fine as well. I cant seem to figure this one out.
Is there an extra setting I am missing?
Thanks for any help.
