Hi all, Im planning a build to add EasyTouch automation to an older pool/spa. I am looking at the PSL4 and am hoping to control these items:
- Intelliflow VS main filter pump via RS232
- Waterfall pump via aux relay
- Pool light via aux relay
- Spa jet blower via aux relay
- Polaris booster pump for pressure cleaner via aux relay. This typically comes on for 3 hours in the middle of the 8 hour main filter pump cycle.
However, it would seem Im one relay short. I would like to avoid the extra expense of PSL8 if possible. As for the booster pump, are there any other options?
- Main filter relay: Since the intelliflow is controlled via serial comms, can i use this relay for my booster somehow?
- Solar, extra bonus relays: Can these be used for the booster?
- Add an extra relay, or does this also require a new main board essentially turning this into a PSL8?
