- Jun 1, 2016
- 269
- Solaxx (Saltron) Reliant / Purechlor R5
My suction side is water tight but apparently not air tight. I have a steady stream of bubbles coming out of the return port into the pool. Not just steady, but also A LOT of bubbles. You can clearly see it, so there is a lot of air in the line.
I have tried a new o-ring on the filter basket. And I have read mixed reviews about pouring water over each union and coupling (doesn’t reach bottom of fitting leaks). Are there any other good ideas to identify where the air leak is originating?
