"Dust" on pool bottom
cbr600
0
Jun 9, 2016
1
Harleysville, PA
After a few years of dealing with this issue I wonder how others deal with it.
System: 12 foot circular above ground, about 43 inches deep. In deep woods with the pollen, bugs and tree junk of the northeast USA, using a a sand filter system. The small creases of the bottom vinyl liner always accumulate what I can only call "dust," as vacuuming it up only leads to it being redeposited a day later. This material is passing through the filter system it appears because it is so fine.
Anyone else seeing this? If so how do you deal with it?
CB
Welcome to TFP!
While it may be your filter system, it’s also possible it’s barely controlled algae. irregular chlorination or high CYA could cause it.
