Hi, I read the conversation "Using the Zodiac 5098 Relay Splitter to Combine Lights" and I'm pretty sure @JamesW reply on Dec 10 , 2023 (...re not needing a splitter) answers my question but I wanted to confirm since my situation involves the main pump relay.
System:
- Jandy RS-8 controller (2006 - HW version MMM -does not support RS-485 communication)
- Pentair Whisperflow Variable Speed pump, hardwired (not via pump relay) with 240v. (Newly installed)
Configuration:
- Pump is set to "external control".
- Pump Speed 1 is connected via low voltage wire to "high voltage" side of relay 6. Pump Speed 2 is connected to relay 7 in the same way. So when Aux 6/Relay 6 is triggered from the RS-8, the contacts to the relay close and trigger Speed 1 on the pump. Same for Relay 7 & Speed.
This works fine for basic operation. (ie relay 6 or 7 come on by time of day or as a "OneTouch" group).
Concern:
It is not fool proof. A user could select Spa (JVA) & heater (not using OneTouch) but the Pool pump will not turn on AND the Jandy RS will think the pump is on (because it sent a signal to the pump relay) so it will allow the heater to come on (heater on but no water flow).
Question:
Is there any reason why I can not or should not wire the low voltage side of the of the Pump relay to the low voltage side of another relay (Aux 7) if I want the 2nd relay (Aux 7) to turn on every time the Pump Relay is energized? See attached diagram.
Thanks
Link to mentioned thread for reference
System:
Configuration:
Concern:
Question:
Thanks
