edit - removed previous issue.. it was resolved.. when the electrician came to test what might be wrong (free i might add) he swapped the stero and pump plugs which are identical connections.
Im dumb, but finally got it.. back to the SWG
Good afternoon folks.
So My hot tub went down about 2 months ago.. Finally got around to diagnosing the issue, and it was the heater.. So I replaced that pain in the butt.
When I was in there I noticed (like every time im in there) the salt water generator is clogged up (needs cleaning)
It is a prozone system.. Prozone - Salt Cell, Prozone Hybrid Salt/Ozone system, w/Terminated Cable, Less Tubing and PZ784 Injector - 600007-4
That thing has been nothing but trouble.. I removed it, and just bypassed the unit... SO its out.
My question is this... for those that may have removed this item, do you just use chlorine and manage it yourself?
I want to look at the drop in generators. They seem easy to clean and I could tuck it behind my filters and it should be fine./.
Anyone use one of those? any recommended?
thanks
thanks
