- Jul 21, 2013
- 55,463
- Plaster
- Pentair Intellichlor IC-60
So I have checked cya and ph this morning. Cya is at about 50 and ph is 7.2. I added 6 lbs of stabilizer. Should I drain a bit to get rid of some cya so I don’t have to use as much liquid chlorine or should I go ahead and just use 6 gallons to reach shock level.
What are you trying to do?
You say you added 6 lbs of stabilizer and now ask about draining to lower CYA???
Why do you need to raise FC to shock level?
Recommended Levels
