My CYA levels now probably average 160. I live in NC and had planned on closing my pool at the end of October. To drain my pool, I’d need a submersible pump and drain into the street drain. I’d need to run the pump for about 4 hours to get to the level I need. Refilling with a garden hose would take about the same amount of time, 4 hours. Here are my questions.
1) Should I drain/refill now before I close or wait to see how much cya levels drop over the winter and then drain/refill before I reopen in the spring?
2) I thought of cutting my drain time in half by using 2 pumps. This is probably a dumb question, but if I used two garden hoses to refill would I also cut the refill time in half? Or am I limited because they both fill from the same water line that comes in from the street?
