- Jun 8, 2020
- 18
- Plaster
- CircuPool RJ-45 Plus
So in April 2021 we had our 26 year old pool re-plastered after a make over the previous Fall (View Picts Here). Several weeks after filling, I converted to Salt and the only issue I had was a constant fight a rising pH. Other than that, everything was fine that summer with the pool. I closed in mid-October, using a solid safety cover, and had these test results:
FC - 7.0 pH - 8 TA - 70 CH - 400
So this spring, I opened in late March only to discover that I had calcium nodules on the walls and floor, and in a couple places on the walls there were solid streaks of the white material. My first test readings after opening were:
FC - 0.0
pH - >8.2 (very bright red)
TA - 65
CH - 350
After reading what some others on this forum had done to get rid of them, over the summer I've kept the CSI to around -.4 and scrubbed to get the plaster smooth again. It was a lot of work but it's done. I just do not want to repeat the process again next year.
I will be closing in a few days and would like to know what I can do to not have a repeat situation next spring. I lowered the TA this season and that helped with slowing down the pH rise. Also, I've just pumped about 6 inches of water out of the pool after the IAN NorEaster that dumped lots of rain here in MD. My current test levels are:
FC - 4.0
pH - 7.5
TA - 60
CH - 300
CSI from Pool Math reads -.62
Are these levels acceptable to close?
I was wondering I worked to keep the pH at perhaps 7.5 or so throughout the winter would that help? Every month or so I can pull a sample of water and see what's happening to the pH and then add liquid acid to the deep end if the pH starts to rise again. And oh, a little liquid chlorine if needed.
Any thoughts? TIA,
Gary.
FC - 0.0
TA - 65
CH - 350
FC - 4.0
pH - 7.5
TA - 60
CH - 300
Any thoughts? TIA,
Gary.
