- May 3, 2007
- 17,393
- Plaster
- Hayward Aqua Rite (T-15)
Is this a booster pump? Water will still travel through it even when off if the outlet is open.
Not sure. They labeled the pump "Cleaner Pump." I also have a pump labeled "Booster Pump" and this pump is for my waterfall.
Does it more or less look like this:
If yes, that is a cleaner booster pump.![]()
My pressure cleaner booster pump is still in place. Yes, water moves through it and out of the cleaner port in the pool. Some day I will remove the pump and plumb the two lines together.
I will take a pic when I get home and post it. Thanks
So if I understand this correctly, I do NOT need to turn on my cleaner (booster) pump at all. Algae will not form in the pipes because water will still run through the pipes, even though the pump is NOT turned on.
Is that correct?
Thank you to the ones who responded. I appreciate it!
you can tell by putting your hand in front of the outlet in the pool when the main pump is on; you'll most likely feel the water flow coming out. Maybe not as strong as other returns, but in mine at least there's quite a bit of flow when the booster is off. To the point that there's sometimes an annoying whistle when the cleaner is disconnected.
Can't you just move a chair or something similar on top of it to block out the sun?
I like the idea, I looked at amazon for boxes and found this one that is made of plastic and would also help in case of rain http://a.co/0zkunGF...this is in reference to the question I made about how to protect the control unit from sun/rain
Maybe there is some debris in the water port? I think there are 2 screws right on top under the cover that give you access to the water diffuser and impeller.
