If the issue is worse after cleaning the basket it's possible the basket is not fully secure and leaking air. A little pool lube on the lid o-ring would fix this if it's the case and if you are super lucky it'll fix the leak entirely.
Entrapment is when a swimmer gets stuck to an underwater drain and can't free themselves. There are a number of fairly recent laws to address this issue and they affect the shape of drain covers, multiple drains connected together etc. Your pump actually has a cut off feature - it will turn off in a restricted flow situation. So if a swimmer fully covers a drain the pump will pull a bunch of negative pressure in that pipe, it will turn off and the check valve would close - potentially trapping that negative pressure and thus the swimmer.
