Wayne,
Most people that run 24/7, want their SWCG to work 24/7.. For the SWCG to work, the "Pool or Spa" circuit has to be on.
This means that you schedule your Pool circuit to run 8 am until 8 am (24 hours...)
Then you turn on "Additional" circuits to make the pump speed up or turn off the additional circuit to make the pump slow down.
Here a made up example..
Pool (1200 RPM) scheduled to run 24/7..
Skim Low (1500 RPM) scheduled to run 10 am until 11 am
Skim High (2000 RPM) scheduled to run 1 pm until 6 pm
Waterfall (2800 RPM) scheduled to run 5 pm until 7 pm
Here is what will happen..
At 8 am the pump starts and runs at 1200 RPM, the SWCG is on and stays on 24/7
At 10 am Skim low comes on and the pump increase speed to 1500 RPM
At 11 am Skim low turns off and the pump slows down to 1200 RPM
At 1 pm Skim High turns on and the pump increase speed to 2000 RPM.
At 5 pm the Waterfall comes on and the pump increase speed to 2800 RPM
At 6 pm Skim High turns off, but since Waterfall is still on the speed remains at 2800 RPM.
At 7 pm Waterfall turns off and the pump speed slows down to 1200 RPM as the Pool circuit is the only circuit still on.
At 8 am everything repeats...
Please let me know it the above example does not make sense.. Below is a screenshot of a similar speed set up..
Disregard the heater circuit at 1000..
