For instance, say one were to have a waterpark in Texas and the waterpark runs off well water, so there is very high calcium hardness. And there are features in this waterpark such as sprayers, slides, etc. And the waterpark has a 1ft deep pool area enclosing everything. And the temperature in the summer is very hot (over 100 degrees F), and there is this hard water coming out of sprayers and impacting all the surfaces around it. I know that keeping the pH lower keeps the calcium dissolved in the water, however, if the water evaporates on the other surfaces before it gets back down to the "pool" part of the water, does the pH value have any effect on if calcium will be deposited on the surfaces that are sprayed with this hard water?
