- Aug 31, 2021
- 217
- Plaster
- Pureline Crystal Pure 60,000
As you may know, the DOE will be prohibiting the sale of many types of incandescent bulbs from July 2023 onward:
As I understand it, these rules apply to "General Service Lamps". Does anyone know if pool light bulbs fall under "General Service Lamps"? According to the following document:
The following lamp types were at once excluded from the definition of "General Service Lamps" (and some may have since been removed from the list):
"appliance lamp; a black light lamp; a bug lamp; a colored lamp; an infrared lamp; a lefthand thread lamp; a marine lamp; a marine signal service lamp; a mine service lamp; a plant light lamp; a reflector lamp; a rough service lamp; a shatter- resistant lamp (including a shatter-proof lamp and a shatterprotected lamp); a sign service lamp; a silver bowl lamp; a showcase lamp; a three-way incandescent lamp"
I don't see pool lights listed (unless these would be considered "appliance lamps")?
Should I stock up on 500w (pool) and 100w (spa) bulbs now? FWIW, the tech at the nearest Leslie's said that the DOE standards apply to <300w bulbs only (so pool 300w and 500w pool light bulbs are ok, 100w spa light bulbs are not). I can't find any info online that corroborates this.
BTW, don't bother calling me an energy hog...since purchasing our house in 2021 I've cut summer electricity usage by ~50% vs the previous owner's usage (smart thermostats, fixing insulation, variable-speed pool pump installed, etc). I just have no interest in upgrading to LEDs, given how many premature $$$ LED fixture failures are discussed on this site (and how rarely we use our pool lights).
U.S. Department of Energy Finalizes Rules to Impose Stringent Efficiency Standard on Most Lamps
Key Takeaways: What Happened: DOE finalized rules to apply the 45 lumens per watt “backstop” efficiency standard to general service lamps and to include five categories of specialty incandescent lamps, incandescent reflector lamps, and a variety of decorative lamps under the definition of...
www.natlawreview.com
