- Aug 29, 2012
- 55
- Plaster
- CircuPool RJ-45 Plus
In the spring, I usually have to waste some water to bring the level down (I do so when backwashing or vacuuming so make the best of the waste). If we have a fairly wet spring I might dump thousands of gallons.
Then summer comes. Here in my corner of Maryland it has been hot and very dry. I’m on a well so filling from the hose is not a great choice. The water is fine but I don’t want to deplete my well or wear out my well pump. Tomorrow I’m paying $280 for 4000 gallons of water, the minimum load, and probably only need 2000.
I always thought it would be nice to have a 1000 tank nearby to put extra water in so I could draw from it at times like this, then fill it back up when the pool level is high. I’d even consider collecting water from the roof through some kind of sediment filter to supplement it if needed.
Does anyone here have some kind of water storage setup? It would come with a high initial cost but it wouldn’t take many years of needing to buy water to pay for itself.
Note that I have a mesh cover, so in winter I would still plane checking and pumping water out to stay well below the skimmer, but I usually let it fill from March-May rain and don’t normally need to buy water in spring for opening. This would only be for summer (drain it in winter).
