Does a Culater work getting rid of copper?Your copper stain treatment did not remove the copper from your water, it only removed the solid copper stain from the wall by making it dissolve back into solution. So you still have copper in your water.
You need to find a pool store that can do a "total copper" test, not just a "free copper" test. Free copper is just the amount of copper ions in solution but does not typically include copper that is sequestered by a metal sequestrant chemical. Total copper uses an acid digestion step which frees up all the copper in solutions and gives you a total amount.
The only way to get rid of the copper is to replace the water. You must empty some volume of pool water and replace it with metal free water.
Moved from here.
