My equipment pad is about 10ft above water level.
Last year, I didn't properly winterize my slide line it cracked.
It's been replaced but the pool company that closed my pool felt there should've been a valve at the bottom of the slide to aid in closing it.
So the jerks cut my line and said they would install a valve when they open it. Well, I'm planning to open myself.
Soooo....do I need a valve there? Any suggestions on type of valve? Any benefit to having a 3-way valve to help with the clean-out?
I also have a clean-out halfway between the pad and the slide. It was done when the line was replaced as an extra precaution.
Any other suggestions?
