- May 17, 2023
- 30
- Plaster
- Pentair Intellichlor IC-40
Hi everyone,
I have a question about my pool setup and would appreciate some advice. My pool was built last year, and I'm experiencing an issue with the spa jets. Two out of the six venturi jets aren't producing bubbles.
Here's some additional information:
- Filter: 60 sq ft DE filter (recently backwashed and properly loaded)
- Multiport Valve: When set to bypass the filter (recirculate), all six jets work properly.
- Flow Meter:
- With filter: 60 GPM at 3,450 RPM
- Bypassing filter: 70 GPM
- Should I add a filter bypass valve that activates only when using the spa?
- Or, would a bigger pump be a better solution?
- Pump: WhisperFlo VST THP 2.6
- Control System: Intellicenter
- What size and type of pump would be recommended?
- Do I need check valves in the bypass line?
- Or, can I simply install a pipe connecting the filter inlet and outlet, activated only for spa use?
