My pool was finished about 18 months ago. I have an in ground floor cleaning system and for the most part it works great, but wanted a little more coverage, so I bought a cheap robot, Apier Seagull about 8 months ago for about $200 to help with some of the dead spots. I have been noticing a bit of white sand in the robot basket almost every time I use it. If I go longer without using it (say a week), I notice more sand. Note that I do not have a sand filter. I have a cartridge filter. This is a gunite/pebble tec pool and I am pretty sure it is not related to that - the sand looks to be the same sand the masons used for all the stonework around the pool. How likely is it that I would have a leak in one of the pipes which would pull in sand from around the pipe? My pool builder claims that the pressure in the line would push the sand away, not let it fall in. Also note that the equipment is about the middle of the water line, so it is always under pressure, even when the pumps are not running.
Any thoughts on this? Is the only way to confirm this by having someone come out and do an ultrasonic test? Any other ideas?
Thanks!
Thanks!
