This is my first year as a pool owner. I have a 12-16' x 32' inground. I bought a set of two solar heating mats (each 2' x 20'). I set them up on the ground behind the pool to see if it made a difference and the answer was yes. Even with that area being partially shaded at times the pool gained about 8 degrees over the course of the week in early August. I ran this off a solar powered 15w pond pump, which worked great as there was no elevation change. If you have a good spot for a ground level system I would recommend this.
However, the mats aren't really in a good spot (partial shade, awkwardly obscuring the deck, unattractive). But now I know it works I'm going to move it to the roof. I'd like to use a separate pump because the available roof is on the opposite end of the pool from the main pump, also I don't want to void the warranty on my pump by messing with it.
My question is, would a 1/10 hp pump be enough power to lift the water 10'? I found one at harbor freight which has 320 gph with 3/4" in and out garden hose style connectors. It states i think 32' lift, and the solar mats are to be used wirh no more than 1/2 hp. Obviously I would use a heat tolerant hose for the outlet. The solar mats have 1 1/2" headers so I would need to use an adapter at the start of the system.
Any thoughts on my idea? Surely someone has rigged something like this before. Thank you!
