Not sure if it’s going to do any good but I like to tinker. I ran a temp air line off my shop compressor to the pool. Then built a little copper aerator I guess. It’s 3/4 type M with an air fitting, check valve to keep water from going back into my air line, then capped. I drilled 20 1/8th holes around the pipe. No idea if it’ll do any good but if it does I’ll probably rebuild it in pex A so I don’t have a copper pipe sitting on my plaster. Seems to be working pretty well and it looks pretty cool running.
Why? Mostly just because and the pool math app recommended dropping the pH to 7.0-7.2 then aerating to get the TA down and pH back up. And it seemed like a fun piddling around project. I’m a remodel contractor so I used what I had laying around.
It really confused my pups.
