- Mar 15, 2023
- 5
- Vinyl
- Intex Krystal Clear
Hi everyone. So am new ABG pool owner, less than 12 hours filled. I made the mistake of backwashing into my pool with the outlet valves shutoff causing dirt (DE I think you call it) to backflow into pool. I didn't realize at the time that my drain hose wasn't flowing water out during Backwash. In fact I checked the eyeglass for debris and found none following the cycle. In fact, pressure was also good but s/have been yellow during Backwashing now that I think about it. So when I returned to filter (following rinse) nothing happened. It was then I realized all valves were closed. Well you guessed it, when I opened the valves, I saw about 30 seconds worth of dirt fill the pool. I went ahead and left the pump in "FP" for the full 24 hour cycle to finish as I had just added sand following fill.
My question is two fold. Do I turn off the pump and wait for Dirt to settle for vacuuming OR should I let the 24 hour cycle finish hoping the water will clear then repeat the cycle until clear? Water does appear a little clearer following 12 hour run and I've been brushing to loosen any dirt and dissolve any salt below but I don't see the bottom yet. Water is cloudy but doesn't really look dirty. Its almost milky white (cloudy). I do NOT want to turn on the SWG until it clear OR is this a mistake? I'm not really sure the SWG should run until the water is clear. Need some advice.
Salt : 3000PPM
Ph : 7.8
FC : 0
Sorry for my rudimentary knowledge and terminology. Still learning via TFP
Salt : 3000PPM
Ph : 7.8
FC : 0
