I cleaned my filter grids yesterday. I felt like I had an excessive amount of DE in the filter, even after multiple backwashes prior to opening it up. When getting ready to refill, I was looking at the sticker on the side of the filter and realized it says to use 4.8 lbs of DE (for my 48 SF filter) and the DE I'm using from Dicalite says to use 7.2 lbs. So even after a backwash and refilling with 80%, I'm using more than 4.8 lbs.
I've found others that say to use 5 lbs and 4 lbs for fresh and after backwash so that's in line with the filter instructions.
Only reason I can think of that dicalite would recommend using 50% more is so you have to come back 50% faster.
Or am I missing something?
