I've got a newly installed EasyTouch 8 with Screenlogic protocol adapter connected. Screenlogic Connect is unable to Configure the system (Hangs up at the initial 'Configure' screen (yellow light flashes at lower left). PA LED shows red and the PA is connected and addressed fine to the router.
Thought I was careful with the PA install but I now suspect that perhaps I did not power the system down when I went to trim and terminate the 22 gauge wires to the PA. Does anyone know if that ScreenLogic behavior would be caused by a burned up Comm Port? Is there any way to definitively diagnose the Comm Port to know if it is burned up or is the motherboard burned up? Are either the mother board or comm port repairable?
Thanks in advance for any help. DB
