- Aug 12, 2017
- 4
- Plaster
- CircuPool RJ-60 Plus
I stopped using my old (broken) pressure-side cleaner a few years ago. At that time, I scheduled the booster pump for the cleaner to run once a day for 5 minutes, just to clean out the water in the pipes and to give the pump a short spin so that it would be in good working order if/when I ever decided to get a new pressure-side cleaner.
Well, I'm now fairly certain I will never get another pressure-side cleaner and I am not aware of any other good use for the booster pump. So I was thinking about just throwing the old booster pump away and capping off the cleaner's PVC inlet/outlet pipes at my equipment pad. My thought was to use my air compressor to try to blow out the water sitting in the soon-to-be-unused pipe and then try to cap the outlet hole in the pool wall with some sort of rubber plug so that water doesn't get back into it.
I'd welcome any advice you might offer on the matter:
i) Should I just keep the old booster pump for some reason? It clutters my equipment pad a bit, but isn't doing any real harm, so I could just continue to ignore it as I have done for the last few years.
ii) Do I not need to worry about water getting in the unused pipe and becoming all stale and nasty?
iii) If I do need to clear the water out of the unused pipe and seal it off, then is a rubber plug of the right size the best approach?
Thank you.
Thank you.
