We are talking to several pool builders about putting in a pool. We are looking at a freeform pool that is roughly 42' x 22' and 3.5' to 8' deep, with an 8' x 10' spa and rock waterfall. I think we are closing in on the design, but the material(s) to use for the deck is still undecided. Some choices are travertine, flagstone, stamped concrete, and pea gravel-like stones embedded in concrete. There are apparent tradeoffs for upfront & maintenance costs, durability, how hot the surface gets, and how slick it is. We are in the greater Houston area, so the temperature of the deck surface is an important consideration. We have asked each builder their thoughts on the tradeoffs between different types. It would be helpful if you got similar answers from the different builders to make an informed decision. Instead, they all have very different views. For example, one builder says they sand set travertine, and another lays it on a concrete base and knocks those that sand set. One says stamped concrete is cheaper than travertine, and another says the opposite. Another claims travertine does not get as hot but can be slick. Another says it is not slippery. One says pea gravel will hurt your feet, and another says it depends on how much aggregate you expose with the acid wash. It has almost come down to picking a builder means narrowing the deck options and the construction method regardless of the fundamental tradeoffs. The one thing many agree on is not recommending a salt-based system using natural stones.
I would be interested in hearing opinions on the different deck options that were not biased by "this is what we know/do." If it matters, the future pool location is surrounded by a few feet of elevation changes in two directions which can cause a river of water to flow through the pool area. We will need a substantial drainage system on the two high sides.
