Hello,
Following SLAM method after opening pool two days ago. Clearing up quickly and I've been vacuuming to waste for the first three vacuums. I can now almost see the bottom of the deep end (8') .
My pool water level was low today so instead of vacuuming to waste I used the filter for the light deposits in the shadow end. I also like to put those fine mesh socks on the outlet jets just in case anything makes it past filter (it also helps me watch the output pressure as I vacuum to ensure no clogs or drops)
As I was cleaning I noticed a debris cloud coming out of the sock.
is this a mechanical issue with the filter? Or a brain issue with the me?
other background
- just replaced filter zeosand with ew zeosand and had backwashed to clean several days before.
- I cleaned and inspected the laterals but didn't see any issue
- alk 100
-ph 7.8
- calc 150 (a little low, will boost)
-fc 16
-cc 1
- cya 40
other background
- alk 100
-ph 7.8
-fc 16
-cc 1
- cya 40
