- Sep 21, 2007
- 115
- Vinyl
- Hayward Aqua Rite (T-15)
My inground pool has built in stairs. I have had an ongoing problem with debris collecting in the stair area. There is only minor improvement when I adjust the position of the eyeballs on the jets.
I do not have any jets in the stair, and there is a jet about 2 ft 'upstream' of the stair opening.
Last week I installed a 90 degree elbow (from the plumbing section of the store) and attached an eyeball to return jet. So far It works fantastic, the water flow bounces upwards off the steps, creates a flow off the wall that keeps the debris out of the stair cutout.
If someone decided to use the elbow as a step, could it crack the threads in the pool wall? Would that be a cut the concrete, and digout to replace the jet?
Is it worth the risk?
I see there various some 90deg elbows available specifically for pool jets. The tradeoff would be keeping a low profile to minimize potential damage to the pool while maintaining a good flow rate.
Here are two Hayward options:
Hayward Slotted Directional Eyeball Pool Wall Fitting Return Jet SP1419A
https://torontopoolsupplies.ca/hayward-spx1419c1-slotted-ball-series-fittings.html
Others include
https://www.spatex.com.au/waterway-1-flexible-90-degree-return-eyeball-1.5-m
Infusion Threaded Inlet V-Fitting
Would you recommend any of these?
This could also be ideal in my neighbours' 1970's inground pool that could use an elbow to achieve a circular flow around the pool.
Others include
