- Jun 18, 2010
- 61
- Plaster
- CircuPool RJ-60 Plus
I just replaced my Polaris booster pump supply line (flexible reinforced hose. When I disconnected the old hose from the tee off if the return pipe, a fair amount of de-cloudy water flowed into the filter pump. I set the backwash valve to CLOSED to stop that and also to stop water from dripping OT of the filter through the booster pump tee. After replacing the hose, I accidentally set the backwash valve to BACKWASH instead of FILTER. Then I turned on the filter pump and it ran for 10 seconds before I realized I was backwashing. I set the backwash valve to FILTER and primed/ started the filter pump. Now my pool is cloudy with de. Should I just run the filter pump until the pool is clear? Should I add a oil more de? There is no way of telling how much I lost into the blue collapsible waste hose.
