Hi all. Season 7 opening our inherited pool, experiencing a new challenge. Our robot has been picking up DE with each clean (see pic for typical amount). I've done about 20-3 hour cleaning cycles since opening the pool a few weeks ago. DE pickup has been fairly consistent. Decided to do some testing and turned off the pump for ~18 hours and let the robot run. By last clean, there was very little DE in the filter.
Well I turned the pump back on this morning, and there was a ton of air in the system, and I was able to see dark (presumably DE filled) water entering the pool via the returns. I guess I had never noticed before because our pump is on a timer and starts at times I'm either not home or typically outside. I've manually started the pump closer to the previous shutoff time (~4 hrs) and observed some bubbles coming out of the returns, but not visible DE like this morning.
I'm assuming this means I have at minimum, an air leak. Suction side? Is this likely my only problem? The only thing different at startup this year was an attempt to fix the o-ring on my air relief valve. I will admit I don't know if I replaced correctly as the o-ring was completed broken, stuck in the valve. Could this be the cause? I have another valve on the way to either compare to or entirely replace my current one.
Any other things I should be checking? No other obvious plumbing leaks that I can see. Any suggestions on how to avoid what happened this morning until the new valve comes, other than running pump constantly or not at all?
Appreciate any guidance!
