TA is the last thing you mess with. It's for when you're bored and want to mess with the pool. It's not harmful to humans --- you've been drinking and bathing in the same fill water. The only reasons to aggressively go after TA are that you're tired of adding acid every single day, or that you're in imminent danger of Calcium scale forming. Otherwise, just maintaining pH will slowly reduce TA.That makes sense about the 60 reading. Should I leave the TA where it is? Or add more muriatic acid to try and get it down? I'm very happy with everything else and it seems I'm settling into about half a gallon of bleach per day! Cheap and easy!!!
Thank you!
