Not new to pool maintenance but new to TFP. We’ve had a hard time getting our pool perfectly clear this season. We can see the bottom but the water isn’t sparkling clear. After being totally fed up with the run around at the pool store and a recommendation from a family member who uses TFP we decided to make the jump. We have the TF-100 kit. Spent a week or so trying to balance the water then learned about doing a SLAM when the water isn’t perfectly clear etc. We’ve been in the SLAM process for 5 days and the pool isn’t clearing up and we are still failing the OCLT. We test every 2ish hours and add 10% liquid chlorine as necessary, vacuum to waste anything that is showing up on the bottom of the pool and brush everyday. This is a vinyl pool with a sand filter. We are in Texas so have been battling the 100 degree temps everyday. Not sure if this is having an affect or not. Do we stay the course? Am I missing something? Definitely reaching the point of frustration as the pool wasn’t green when we started this whole SLAM process just cloudy.
