Hello,
I just opened my pool today and the water temperature is a chilly 56 degrees. I took a water sample and heated the water in the microwave for 20 seconds. I then measured my cyanuric acid and it was 40. I was expecting a zero reading. Is it normal to have a reading this high when starting the season? I don't want to add chlorine stabilizer and then overshoot my mark. Did I do the right thing by heating the water?
I believe I finished the 2022 pool season with a cyanuric acid reading between 40 & 50.
Any advice would be appreciated.
Thank you.
Thank you.
