We opened up our pool and are getting ready to start a SLAM. It is going to be windy and rainy this week so I'm afraid that this SLAM is going to be challenging. Before I start the SLAM, I have a few questions:
1. Is there an alternative method to the “sock in front of a return” method that is recommended on here to increase CYA, other than using expensive liquid CYA? It is very windy today so I really don’t want to tie a sock filled with CYA in front of a return because I’m worried that it could fall into the pool. I also do not want to put it into the skimmer since my skimmer could fill up with leaves quickly because of the high winds and the SLAM will require backwashing often. Instead of using a sock filled with stabilizer, could I put 24 oz of stabilizer into an 8 gallon bucket of warm water and set it outside to dissolve in the hot sun for several hours and then pour it around the perimeter of the pool or in front of a return jet? If this wouldn’t likely work, is there any problem with just using Dichlor or Trichlor shock if pool math is used to determine when to stop using it? It looks like CYA is around 20 so I won't have to add much stabilizer or stabilized shock.
2. When adding stabilizer or Dichlor/Trichlor shock to the pool before a SLAM, is it best to adjust PH to higher than 7.2-7.4 to compensate for the expected PH drop? In other words, if the pool math calculator says that the stabilizer or Dichlor that you plan on adding will lower PH by .5, should you start off with a PH of at least 7.7 so PH won’t dip down below 7.2? I’ve got an older pump so I don’t want to risk any damage to my pump from low PH. PH is currently 7.2 and TA is 70 but I could increase it if needed.
3. How often do I need to backwash and vacuum during a SLAM? If we end up getting a lot of rain with high winds as expected, we may end up getting a lot of leaves in the pool and I may not be able to go out as often to backwash and vacuum. I would like to backwash as infrequently as possible to avoid losing CYA and other chemicals since the rain may dilute the chemicals too.
