First time poster here. I started using TFP last year when I found this site, ordered the TF-100 and began using the pool math App. I didn't seem to be holding chlorine and found out my CYA was low so worked on getting that raised up prior to closing down the pool last year. This year, I opened the pool and it looked great visually. My CYA was at 0 though. I bought Dry Stabilizer and put it in a sock in front of the return/in the skimmer as I worked on raising it up. I had to SLAM at one point and as I scrubbed the pool I found some white almost plastic like substance growing in the corners of my steps. I scrubbed everything by hand really well in the creases, around the lights etc... I passed the OCLT and CC were back to 0. I had the CYA up to 40 before we left on vacation in mid-June. During this time, I had been adding liquid chlorine to keep the levels where needed as I figured the stabilizer still needed to get higher. While we were away, my sister-in-law was watching the house and checking the pool for us. It started to get cloudy, so I had her bring it to SLAM level and it cleared up. She continued to add some chlorine, but not SLAM. When we got back home, I checked everything and my levels were:
FC 1.0
CC .5
PH 7.4
TA - 110
CYA - 0
No idea how my CYA got to 0 again. I bought some Liquid Stabilizer thinking that would get in the pool more quickly. I added it and the next day the pool was cloudy. I started to SLAM 6 days ago. By the next day, the pool had cleared up, but I continue to lose chlorine, and my CC's are generally .5 or 1. The pool is currently crystal clear and I have scrubbed, checked creases and nooks but don't see anything anywhere. I let up a little on the 3rd as we had people over, but was right back on the SLAM after that. Last night, my overnight chorine loss was 1.0. Here are some of the latest readings after each reading, I add liquid chlorine to raise back up to SLAM level (10) based on the Pool Math App.
7/4
2:00 p.m. FC = 2.0 CC = 0.5
7:52 p..m FC = 1.0 CC= 0.5
7/5
6:28 a.m. FC = 9.0. CC = 0.5
2:00 p.m. FC = 1.0 CC= 0.5
6:32 p.m FC = 5.0. CC = 0.5
10:19 p.m. FC = 5.0 CC = 1.0
Even though I only lost 1.0 from the 4th to 5th. overnight, I don't feel like I am done with these readings.... Should I be adding more CYA back in now or wait until I am done with the SLAM? I just don't want it to be gone again for whatever reason. Thanks for any help and advice.
FC 1.0
CC .5
PH 7.4
TA - 110
CYA - 0
7/4
7/5
