Do not use CalHypo tabs in that feeder. They are not as firm/compressed and dissolve quicker than the TriChlor tabs. They will just plug up those feeders. Plus, from a safety standpoint you should never mix chlorine types in any enclosed space like that feeder as it can have explosive results.
Pool Chemical Explosion Accident Analysis and Investigation at chemaxx.com
Pool Chemical Explosion - YouTube
You have high CYA because Trichlor tabs are almost half CYA in the chemical compound. It has nothing to do with your volcano or acid rain.
Okay now I'm a bit confused and a bit scared. The last thing I want is an explosion. So I shouldn't use hypo cal tabs in the feeders and I won't be able to get the board to okay a liquid chlorine feeder anytime soon. So do I continue with the trichloro tabs but continue to use my methods of shock treatment. And when I can get away with it drain the water and add new. "Something else the board doesn't want to allow" to keep my CYA down to reasonable levels.
