Hi everyone, I've got a weird problem here and I'm not sure if I should trust my test results.
I inherited a pool a year ago and used a Taylor test kit to get a CYA reading of ~180. Obviously not good, but I put off draining the pool at the time and instead only switched from stabilized to unstabilized chlorine. Now, a year later, I've tested the CYA again and got a reading of 0.
Should I trust this result and now try to boost the CYA? I'm not sure how to explain that drop, given that CYA doesn't evaporate and breaks down slowly.
Any help is appreciated. Thanks!
