Is it possible to loose over 10ppm ( more closer to 20ppm) in one month?
I’m in the South of Spain. My pools water temperature has been around 30C or slightly higher for the past 3 months. I got my Taylor test kit on 13th July and immediately tested the cya, because I’d been relying on test strips before and we all know how inaccurate they are, but it’s the only thing they sell round here (I had to send off online for the Taylor kit and wait over 6 weeks for delivery from the States)
I followed the instructions here about testing - glance at the black dot, back to the sun, waist level, And got a reading of 70ppm. I checked with a friend if they also thought it was 70 by just glancing for the dot, and they agreed with me.
So I’ve been adding liquid chlorine 14% every day, and my pool is crystal clear. I’ve never had such sparkling, clear water!
Today I checked my cya levels and the black dot disappeared a hairs width under the 50ppm line.
I checked 3 or 4 times, and each time the same.
Is it possible to loose that much cya in 4 weeks?
My pool is in full sun 12 hours a day.
It’s used each day by 3 people at the most for 2 hours a day.
I’ve been keeping the chlorine levels at 7-8ppm (occasionally 9ppm)
The pH drifts upwards (7,8 -8) but I manage to get it down to 7,4 with muriatic acid once a week. My fill water has a high TA, hence my pool has TA 100 - 120. I’m guessing that is the reason my pH drifts up. But I’m not so concerned about TA. It’s my cya that has me perplexed…
Thanks in advance for your thoughts on this.
Elaine
Elaine
