7/3 65/
7/3 Added 1# dry stabilizer
7/7 90/
7/12 85/
7/17 70/425
7/17 (Leslie’s 102/358)
7/30 95/500
I am only looking at what has occurred in July.
Need to confirm - do you have an autofill? You indicated you added water but want to confirm about the autofill.
Your CYA is bouncing around. 65 before addition of 1 lb dry stabilizer, then up to 90ppm 4 days later, then back down to 70ppm 10 days after that. Then Leslies test is 100 and your retest on same day is 95.
Tap water does not have CYA so it comes from the 1lb dry stabilizer that was added or via any trichlor pucks.
Need to consider testing error with CYA going up then back down unless you backwashed the filter and drained significant amount of water. That would lower CYA some, if you added tap water after the backwash.
Same for CH. Most areas in TX have hard water. Have you tested your tap water? That is probably adding CH each time to fill the pool due to evaporation or back washing.
Try this for CYA testing
1. Make your 50/50 solution using your pool water and the R-0013 reagent per test instructions.
2. Mix it and let it sit for 30 seconds per the instructions
3. Rather than looking down the tube at the black dot and pouring your mixed solution. I suggest you squirt enough in your tube to a specific mark - such a 100. Then look in the tube for the black dot. If you see it, then squirt in more mixture to the 90 mark, then look in the tube for the black dot. Continue this for each decade graduation (i.e. 80, 70, etc.)
4. On the one you cannot see the dot then the previous mark is your CYA level. So if you saw the black dot at 50 but not at the 40 mark then your CYA is 50.
5. This way you are not staring at the black dot constantly and seeing it regardless.
6. Also, by filling to each decade mark, you ensure that you report CYA in decade numbers.
