How quickly are you doing the FAS-DPD test? Just want to make sure you are not letting the sample sit too long during the CC test and getting a false reading.
Yet another person is doomed by the new zombie algae....I have nothing to add other than I have been dealing with a similar problem for almost 2 months, with no end in site!
Hope you figure it out, I will be watching your thread!
I test within seconds of finishing the FC test. I can only conclude there is something hidden in my water that the chlorine is fighting, or there is a problem with my reagent. Logically, I don't think there is anything wrong with the reagents.
Have you been slamming continuously? What test kit are you using?
FC -
CC -
pH - Skip this one
TA - What was your result? How did you know when the test was completed
CH - Skip this one
CYA - Result? Do this test three times by pouring the pool/reqagent mixtue back and forth essentially "redoing the test each time....no hurry. Take the average of those three and tell us what your average was.
None of these have to be "perfect" but rather it will help give us an idea of how you are testing for repeatability and precision.
FC - What was your results? How did you know that was you the end of your test?
- same questions for the CC....what was result and how did you know that result ended your test.
pH - Skip this one
TA - Same as above.....how did you know when the test was complete?
CH - Skip it.
CYA - skip it....you've essentially done it three times alrewady
