Is there a way to create a circuit in Screenlogic that mimics the "Spa" circuit, but just has a lower pump rpm? Right now my Spa setting sets the jets to 3450 rpm and has lots of bubbles in the spa. Sometimes I'd like to keep the heat going and not have the bubbles. Ideally, I would create some kind of "Spa Low" setting that keeps the valves in the spa setup, keeps the heater on, and only pushes the pump to 2000 rpm. I can get on my phone and manually change the rpms on the app, but this needs to be changed back afterwards and is a bit of a PITA.
I have setup an Alexa near my spa and have programmed most of what I've found in the Pentair Screenlogic skill to be able to change the spa while I'm in it - things like the lights, the mode, and features. I think the way to do this is that I need another circuit that uses the same valve and heater settings as the Spa circuit. How can I do this? Wire jumpers? Settings?
Any help would be greatly appreciated!
