Cracked stand pipe
Lucky92
3
Illinois
Hey all,
While changing sand out of my filter I noticed a small crack towards the top of the pipe, up by where the multidirectional mechanism rests in.
Can I repair this with some flex seal tape? or could I trim out the cracked area, put a coupler in and add pipe to fix the length?
Thank you!
Welcome! :wave: Curious, is the crack at the very top of the open end traveling downward? If so, how far? Is it concealed by the MPV when seated, or does it extended below that? I would be more inclined to cut, then use a coupler with a fresh piece to go into the MPV.
