A fitting in the return line cracked and needs to be replaced (see pictures). I was replacing the booster pump hoses and I guess I ate too many Wheaties this morning.
The 'T' with "Cleaner" on it is ok - the '90' below it with the arrow pointing to the right is cracked on the back side. Is the T and the 90 a single unit or, is the 90 threaded into the T? If it's threaded, and it looks like it is, this should be an easy fix. It looks like a 2" 90 with a couple reducers (2 x 1.5 and 1.5 x .75) threaded into it, but I can't tell for sure. Any suggestions? Thank you in advance!![IMG_3625.jpg IMG_3625.jpg](https://www.troublefreepool.com/data/attachments/135/135372-cc8366b748b0b38bf95063082d958136.jpg)
![IMG_3626.jpg IMG_3626.jpg](https://www.troublefreepool.com/data/attachments/135/135373-703f8d1acecca77e2ff3be31a21e6acc.jpg)
