Hey everyone, now before you go in on me let me promise you if this doesn’t work I promise to do it right!
I recently acquired a Perflex EC40 filter from marketplace. I figured it would be awesome for our 18’ Intex. Well upon further inspection I found the tube sheets (both top and bottom) were cracked right where the rod pokes through. I assume this is the common place these fail after years of bumping. My question, since the pressure in these filters shouldn’t go over 20(ish)PSI, and the bumping could be done carefully or just not at all (change the powder and clean internally every time), what are the chances this repair could work using JB water weld epoxy putty? Have any of you tried this with yours?
