What fun. I've had a small leak on the side of my sand filter tank since last year. It initially wasn't much, this year it got worse so I replaced the O-ring between the multi port and the tank making sure everything was clean and lubed. I originally thought it looked like it was leaking right under the V-clamp. The lighting in the equipment shed is lousy so I got a flash light and inspected it and below is what I found. The smaller red area is where there are two leaks. The larger area is cracked but not leaking.
When I did find a replacement tank for my 25 year old filter it was $465.00. Can anyone suggest a way this might be fixed without replacing it? I figure I've got nothing to lose trying to fix before I replace.
Rick
Rick
