What’s the condition of the expansion joint between the coping and the pool deck?Hello, any idea why this pool has cracked? The crack runs along both sides, im guessing the pool cover rails and skimmer boxes are the reason but would like to repair thjs if possible and prevent the problem from coming back
. Pool is 20k inground not salt. Thank you.
I just did the mastic myself actually. It was in bad shape on one side, dried out and not sealing out water whatsoever. On the other side of the pool the mastic is still sealing out water but it's a bit dry and not flexible in some places. No obvious cracking of coping stones or anything from above. Here's a better picture of the joint and crack. It's hard to tell in the 2nd pic but that crack goes the whole length of pool all the way to skimmer box. The crack is present on the opposite side of the pool but its not nearly as bad.What’s the condition of the expansion joint between the coping and the pool deck?
So, to repair this I would detach the rail for the pool cover, break out the coping stones and then...remove the mortar they are sitting in and re apply mortar?Seemingly a defect in the bond beam.
That kind of crack can point to a lack of expansion joint. Before you replaced the mastic, was there an actual gap between the paver base and the pool wall (bond beam)? Sometimes a concrete paver base is poured right up against the pool wall without leaving an expansion gap there. Then when that giant slab expands and presses on the pool wall, something has to “give” and causes a crack like you see. I’d definately check what’s under the pavers and see.I just did the mastic myself actually. It was in bad shape on one side, dried out and not sealing out water whatsoever. On the other side of the pool the mastic is still sealing out water but it's a bit dry and not flexible in some places. No obvious cracking of coping stones or anything from above. Here's a better picture of the joint and crack. It's hard to tell in the 2nd pic but that crack goes the whole length of pool all the way to skimmer box. The crack is present on the opposite side of the pool but its not nearly as bad.
