- May 23, 2019
- 64
- Plaster
- Pentair Intellichlor IC-40
My calcium hardness has gotten very high (~1,200) due to my local hard water supply and three summers of evaporation. I don't want to drain and refill due to the current severe drought. Unless I want to deal with high calcium forever, I think I need to get a water softener for my autofill line. Is there a realistic chance this will bring down calcium levels noticeably over time, or should I plan to have the pool treated with reverse osmosis and start over with low calcium hardness and then use softened water? If anyone has a referral for a good RO company in Southern California, please share.
For the water softener, I have a couple of installation options. I can do a traditional installation so that it serves my whole house (except exterior irrigation). I think I also have the option to install a dedicated softener at my pool equipment pad because my autofill line routes through there and there is electrical power as well as a drain to the sewer (for backwashing). Has anyone tried adding a water softener at their equipment pad? Were there any notable pros or cons? I definitely want an automated system and not something that requires manual backwashing.
Are there any other options or solutions I should be considering for dealing with hard water long-term? I read a bit on the forums about using an RO unit on the autofill line but it sounded like that might waste more water than a softener.
Thanks in advance for any advice!
